hookedonblue
Hey Boys. Whats The Best Jets You Can Reccomend To Use On A 2002 Srx. Our Temperatures Here In Newfoundland Generally Run Around 0 - Minus 15 Most Of The Times. My Machine Is Equipped With Dcs My Dealer Jetted My Machine 2 Sizes Oversize To Eliminate Dcs Light From Comming On. But I Think It Was Because Of The Spark Plugs.
Let Me Know.
Let Me Know.
Brad
- May 23, 2003
if you jet to the 01 jetting of 150/148.8/148.8 you should be good
Bigmax
If those temps are Fahrenheit then you should be good to go. Two sizes up on the mains from '02 would give you the same jetting as the '01. If those temps are Celsius then I would probably go back to stock or meet in the middle at 148.8/147.5/147.5.
yammiman
I went in the middle with my 02 like Bigmax suggest and it has worked great!
hookedonblue
Thanks Guys
YAMMIEGOD3:16
RUN HIGH OCTANE FUEL AT LEAST 50/50 PRE-MIX WITH PUMP AND YOU CAN KEEP STOCK JETTING. IF NOT 01 SPEC WILL WORK. 3:16 (yammie tony)
jmp2204
i run stock jetting with prem(min 91) fuel with 0 problems
