Phazer/Phazer II ?
northern srx
Lifetime VIP Member
georgetown ontario
The track length changed from early model years '84-'89 to '90-'94 models. Would the rear suspensions be the same, only that they were relocated further back or are the rails longer in '90-'94 models? As well, would any one know the weight of these skids? Thanks Chris.
skids are different, as are the mounting points. both are the same distance from the driveshaft to the front mount, but the rear mounts are placed about 2.5" further back and an upper crosshaft to support the track was used on the 121 pz's.
not that bad of a project converting the 116's to 121's. i would estimate the weight of either skid at around 60 lbs.
