hookedonblue
How The Hell Do Ya Get Exaust Residue Off Of The Underside And Side Of Belly Pan Of You Srx Boys. Man It Looks So Bad. It Gotta Come Off. Let Me Know How. Thanks
unimog
Simple Green cleans carbon off the bellypan pretty well, for a quick clean, brakleen also does pretty good.
OK, I'll let my secret out for a clean belly. Wessley's tire bleach. Have fun.
yammiman
Bio-Kleen is the best I've found - spray it on, and rinse it off - super stuff
hookedonblue
Hey Maddog, Where Do You Get That Stuff? And How About You Yammiman, Where Do You Get Boi-kleen? Thanks Boys.
yammiman
Go to biokleen.com - the product is Sled Bright belly pan cleaner
Auto Parts Store, Walmart anywhere really.
NORTHMANSX
i use castrol super clean, it works on anything.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
I had the same problem with my sled, it was almost black all around there but then I found some orange cleaning solution and sprayed that on. It work so well that when I sprayed it on, I could see it drip BLACK! Just the solution alone took it off. I was very impressed.
hookedonblue
thanks all you guys, just wanted to let you know i found a good cleaner to use. i lucked into it today from my local zep rep. its called zep 50. man it tears off the carbon like you wouldnt believe. it was effortless. cleaner tahn new now. give it a try boys...
edb
cleaner
Honda Brite works excellent. Any Honda dealer has it.
Edb.
Edb.
