does anyone have a high altitude clutch and jetting chart for 4-6 thousand feet for this sled, that could be posted. Thanks
I don't have the chart but the 2001 mtn max 600
Runs all the same specs on the carbs except the main jets.
Pto cylinder 136.8
center/mag 133.8.
The stock 47 helix is a little steep for altitude.
Get a oem 43 degree keep the wrap the same at 80 degrees and remove all the rivets and you should be spot on.
If this is a once and a while trip this is the lowest budget set up or are you only going to be riding and them altitudes all the time?
Pto cylinder 136.8
center/mag 133.8.
