MM70001
Does Yamaha shops use a circlip installation tool like skidoo? Or is there another technique suggested?
Also is there any sealing agent used on head or base gaskets or are they assembled dry?
super1c
Super Moderator
Is this a new install with new gaskets? New gaskets are left dry, used gaskets i used some copper spray. Not sure on the circlip never been that far in yet!
staggs65
super1c said:Is this a new install with new gaskets? New gaskets are left dry, used gaskets i used some copper spray. Not sure on the circlip never been that far in yet!
if you've ever pulled a piston you've done a circlip. I usually do them with my fingers. not a lot to them. I'm sure there's a tool but for a piece of 1/16 wire.......
super1c
Super Moderator
No piston just pulled a jug to get a busted exhaust bolt out. The guys told me new gaskets dry and seeing i left the base gasket as is to just use cooper spray. Never had to do a rebuild yet. But will this next off season. My vipers getting up there in miles.
