I was considering buying an SRX but I mostly mountain ride. So the trails are mostly "soft" or "packed powder." I was wondering what is the largest sized lugs you can run without major mods? Can you run 2" lugs.
if you remove your front exchanger protectors,should be good with 1.5 track,but 1.75 should clear also...
Good to know. That's probably all I really need. Thanks.
