FJViper
Rear pivot arm washers?
Hey guys question for you. Getting ready to re-install the rear pivot arm back onto my rails (Viper Pro-Action skid). This is the shaft that mounts with 14mm bolts to the rail. I didn't notice any washers in between the arm and the rail itself when I took it apart??? The parts diagram shows 1 washer on each side at the end of the scissor shaft and the rail itself? I do have some play in there so I was was going to put shims in anyway. Should I use some thin regular steel washers or maybe some aluminum shims instead? Maybe someone could check their skid to see if there are bushings or washers?
#50 on the diagram
http://www.partforyamaha.com/pages/...OWMOBILE)/TRACK_SUSPENSION_2_(SXV700G_-_2002)
#50 on the diagram
FJViper
Anyone????????????? Not sure if it is a thin washer or a thick washer that goes in there.
a little over 2mm thick, maybe near 2.5mm.
FJViper
Thanks Snowdad! I appreciate it!
