Is there any difference from a fully clipped track to a track that is clipped every third window?
Dow it hav anything to do with hyfax wear?
Just wondering if it is worth it Togo with a fully clipped track.
Thx
Thx
A couple of bucks
If your riding conditions are good-great, a track w/ every other or every third would be fine. As you are in Ontario, I'm figuring you'ld be just fine. Cannot really speak for the track wear though.
Are all of the windows @ the clips open or are some of them closed?
SWEDE
I've been told that you get less drag,but more slide wear with a fully clipped track. Clipped every thirds hold more snow which lubes slides better, but creates more drag with the slides rubbing on the rubber sections more.
Suprx125
Fully clipped tracks are usually more $$ also.
A couple of bucks
On your current track.A couple of bucks said:Are all of the windows @ the clips open or are some of them closed?
A couple of bucks said:On your current track.
My current track is stock, fully clipped open every window.
I want to upgrade to a 1.25 ripsaw the fully clipped one is $536, and the clipped every third window every window open one is $499.
Suprx125
I had 8600 miles on my factory 1.25 ripsaw that was clipped every 3rd window and it was in great shape. Only reason I took it off is because I stretched it to a 144. I think you'll be fine with the 3rd window, but it comes down to what you want to spend.
A couple of bucks
Are you allllllllllllways in good snow conditions?
A couple of bucks
And do you ever see yourself putting extrovert drivers on.
A couple of bucks
And are your current hyfax the standard black or colored OEMs or what?
snoprokidf6
Go with the fully clipped, less drag, same hyfax wear from my experiences
I ride pretty much only groomed trails, every now and then go off trail
I just bought the sled and it came with blue oem, but next year I'm going to put graphite ones on.
A couple of bucks
I'd go w/ the fully clipped.
yournytech
YourNYTech
...and a little heavier.Suprx125 said:Fully clipped tracks are usually more $$ also.
