crazy question
needaSRX
Manitoba
FLYWHEEL question
I have friend here that did my bottomend this summer for me crank seals, checked the crank over still with in specs he told me, water pump rebuild, ;)!
My question is:
My flywheel had nicks and dents on the 2 of the 3 bumps but still it worked fine, started the sled everytime now, he told me for racing I'm loosing HP from these dents and nicks is this True :dunno:
this is the other problem I put everything back together bought a flywheel from a member here, he put that one on, that is the only differance from it running last year now it won't fire it has no spark :o|
what type of flywheel is this the part # on the inside is F4T36971 2401
should of brought the SRX motor to me to rebuild..mine still going strong two season's since rebuild.Don't know what to tell you.What year sled did the flywheel you have now come from.??
part number for new flywheel is the same for 2000 and up SRX's(8DN-81450-00-00)The 98's and 99's are totally different beasts and way cheaper..Brand new not from a dealer I can find for $375..dealer probably $600..Try switching your stator also and see what gives.You may have to spend a few more bucks to solve this one Andy..sorry to say.
I'm not going too buy brand new flywheel WAY too much $$$$$$ like 500+ here no way
Like I said I have 2 stators that I tried and an extra CDI unit still no spark
these stators checked a room temp .215 ohms on the pickup coil and .7 across the 3 white wires
Andy where are you???? TRY by cutting off the load control relay and see if anything changes.
Check your pickup coil resistance as well.
white/red-------white/green
189-231 ohms at 20 C
diagram for control relay
I tried that and it tested out too .215 between the wires at room temp, I have 2 stators and the flywheel with me here the sled is down the road in the garage
you got to try unplugging the control relay as well,by pass's all dash and lighting and simply get's it to do a start procedure.This will eliminate any short or ground anywhere...
