Adjustments with Ohlins Shock Extensions
jaydaniels
Amherst NS
I just installed the Ohlins Shock Extensions on my sled and am trying to find the best setup. Right now it seems very stiff. Should you adjust spring preload or just use the clickers on the shock itself. I set my compression dampening to the softest position and it still seems very stiff. Any advice would be appreciated.
set your damper clicker to 50% (middle of your adjustment) set the springs light with little to no preload. good place to start. ski
I had a shop install them for me so they may not have adjusted the preload. I think I will try with the softest setting and then increase untill I find they bottom on the worst hits. Thanks for the advice.
