Newr Yamaha clutch on a Phazer II??
sleddineinar
Ramsey Minnesota, United States
Can it be done? Will it bolt right up? Primary & secondary or just the primary? I've been thinking about replacing the old primary on my 90 phazer II. I'd pull my 700SX clutch and try it, but the 2 sleds are about 200 miles apart right now. So I was wondering if someone has done this. I realize the weights/rivets and springs would have to change.
yes it will work but you will need a 95 vmax secondary ........ as from what ihave been told the newer reverse cams wil not slide on far enough .............i did the switch on my 88- EX 570 but i use a p-85 primary
