2002viper
any one have instructions how to change the track on a 1983 enticer?
Yamaha Nutz
First Remove The Rear Skid
Then Open The Chain Case And Take The Gears And Chain Off
Then Take The 3 Bolts Out Of The Speedo Bearing Retainer Flip Sled Up On Its Side And Pull The Drive Shaft Out Of The Chain Case And Tip The Axle And Pull The Track Out .............this Is The Quick Way Make Sure To Check The Speedo Side Bearing And Replace If It Is Remotely Bad
2002viper
thanks> I'll give it a shot. The skid hasn't been out in years and the track niether. I'll see how it goes. I did my polaris before and it was pretty straight forward.
