YamahaVmax600
i need some help. i recently bought a 03 rx1 skid to put in my 96 yamaha vmax. im just wondering if anyone has done it or could give me some tip on putting it in
thanks
thanks
just pull all measurements from any pro action sled from the driveshaft back and down from the top of the tunnel. you will need spacers for the front two shafts and just use your side brackets with the three bolts to attach the rear arm. The rear shaft should be the correct with these on it. make sure you use longer bolts that are hardened for the front arm. once it is in, you can get the initial set reading the thread below. also there are some parts to upgrade that skid mentioned in it. The rx skids have alot of plastic bushings instead of bearings.
ALLSEASONRIDER
As BETHEVIPER said above...also you may want to visit vmax4.com and look in the tech section. Wildmax has an install with all the info you will need.
