are the starters interchangable between the sx xt ect.. also are they the same in the 96 and 97? im looking to set up an electric start on my 98 vmax 600sx twin. what is required as far as starter mounting plate wirering does the stock regulator charge the battery? do i need to buy a relay? where does the battery get located?
gil7247
Give Super1c (Chris) a holler, he added electric start to all 3 of his Vipers, he's real familiar with it.and a great guy to boot! Gil
super1c
Super Moderator
Ahhhh thanks gil, feelin the love!. LOL! Any electric start from any proaction sled 97 and up will work. Best to find as a take off with all the parts. Keep an eye out here or e bay. The ony difference between the years was the connection to the ignition. You can simply cut the ends off and hardwire or make jumpers with push pin electrical connectors. Ive done both, work just fine. All proaction sleds are pre wired for them and the holes are in the block for the starter and holes in back of clutch for ring gear. There is a great write up in the tech section with step by step. Or do a search and you will find tons of good pic's and write ups. Very easy to do! Let me know if ya need any help! Chris http://www.totallyamaha.com/snowmobiles/aaTECH/electric_start/electric_start_install.htm
