Bar riser?? On 2000 sxr 700
ryan123
Appleton,wi
Want to put a 3" bar riser on my 2000 sxr 700. If I install it will I have to change my oil calibration?? Don't want to install it and blow it up with getting lesser than norm oil or have it to rich. Let me know
If cables are run right 3 riser is biggest you can use. With no prob
So loosen all cable ties and what not instal and go from there?? Any tips on running cables right??
Go to the home page. Click on snowmobile tech, down the bottom is mods,trick etc. click on that and then go to max bar riser. That should get you started. Other than that try doing a search.
