MM70001
I need to set up my carb needles as I am installing Bender triple pipes on my Mountain Max with the airbox mod.Could somone please suggest needle positions for 2000 feet?at -20f(-15c)I know I must remove the two 2.5mm allen screws from the slide,must I disturb the slide linkage to remove the needles?What is the most practical method?
chris700readhead
To get the slides out I loosen the Philips screw that holds the linkage to the shaft, loosen the Allen screws with the slide all the way down, then pull the linkage up a little slide the clip off and then pull the slide out. Hope that helps you. Chris
