cmatica
I would like to use ODI lock ons, or something similar on my SRX and RX.
How do I go about this? do I have to drill out the rivet to remove the grip. Do I put on aftermarket heaters that stick on the bars? Do I just wire them into the old wires? Will grips like odis work with heaters?
You get the point, let me know your thoughts please.
Thanks in advance
Thanks in advance
Yes, drill out the rivets to remove the factory grips. You will have to check the ohms on the aftermarket heaters and make sure you set them up the match the factory grip heater ohms. I have used RSI heaters with no issues.
As far as the ODI Lock Ons, can't help you there
cmatica
Ok sounds great, do you (or anyone else reading) know the OHMs ratings im looking for?
Also what other type grips have you used that worked (or didnt)
They measure 1.5k ohms each. In series they measure 3.4k ohms
cmatica
Anyone know if ODI or any other grips are going to work with aftermarket heaters???
