MM700 triple pipe clutching
kimoaj
Norway
Hi!
A friend of mine exploded his primary clutch (can take pictures if wanted) and I put a primary from a 97 V-Max 700 on it and now it needs a new setup.
The sled has triple pipes, will a Heelclicker "stock" yamaha kit do the job ? Will it have the necessary adjustment possibilities?
Any opinions will be highly appreciated:)
Joakim
The heelclickers will do the job, you just need the proper helix and spring for the secondary. You can buy a complete primary off ebay, or you can buy from Frank in Meistervik. You should measure the runout on the crank after the blow up.
