NEWBIE QUESTION: Wheels in rear, on the INSIDE of track on axle....
minnesotasx700
Duluth, MN
Okay, so picked up a 98 sx700. All the bogeys etc look new, EXCEPT.... ONE of the wheels on the short axle, that runs towards the back of the track I guess, and is on the inside (2 wheels on short axle). Anyways, one wheel was missing all of the outer rubber coating.... so it was down to the metal wheel. I pulled the two clamp/c-pins (or whatever they're called) off, than hammered the wheel off. The bearing stayed on the shaft/axle though? Now, the other wheel is good... but I noticed BOTH bearings seem to grind SLIGHTLY. Now, my questions;
1.) How the heck do I get the bearing off of the axle
2.) Do I need a whole new wheel (one with rubber gone) or is there a rubber replacement? Either way, I need part numbers and what are they called!!!???
FOUND the WHOLE assembly on e-bay, but spendy... and no guarantee the bearings are good? SO, that said, look at the picture please and tell me what I'm looking at! lol, thanks!!!!
thats simply a crosshaft, for lack of a better term.
best to use a press to get the bearings off the shaft. with the dissimilar metals, its almost an instant stick.
no replacing the rubber, gotta do the whole wheel. if your lacking a press, there are some animal alternatives for bearing removal.
what was the ebay price? i may have a few of those assemblies.
Ebay was 66.00 after shipping! That's with used wheels and used bearings.... I technically only need one wheel.... but... both bearings SHOULD be done.... what is the name of the wheel? I need to know if I am to order a NEW one? or???? Oh.... and, NO PRESS :(
I've got a couple of those plastic wheels with good bearings in them. Say $25 shipped to you unless you are in the Brainerd area and want to pick them up.
Wheel is removed.... just need to get bearing off.... and YES, 25.00 bucks is a go! PM me a paypal address? And I'll shoot you my address! THANKS.... any suggestions on popping that bearing off without a puller? And how do I press the replacement wheel and bearing back on....????? THANKS ALL
I've always just set them in a vise, cleaned the shaft up with some emery cloth, squirt a little lube on them, beat them off with a hammer, clean things up, and push the new ones on. I'll look and see if I have a shaft when I go put the dog in the garage for the night
Well, I have the shaft? And the other wheel on it is good???? Okay, I will knock the bearing off with a hammer... than slide the other one on and than replace the two clips...?
minnesotasx700 said:
Okay, I will knock the bearing off with a hammer... than slide the other one on?
When the new bearing goes on, you can get it all the way down to where it belongs by using a deep well socket that juuuust fits over the shaft. Insure the socket mates up to the metal portions of the bearing and not the soft plastic.
TO: Mysledblows..... payment sent two days ago, site shows that you have read my messages. I have NOT received any info now since I paypal'd you? No reply to my messages, no tracking numbers....? Hoping all is legit? Thanks
I have bought a few things from Ryan (including real nice used skid) and he's always been more than good to me. Don't worry, he'll come through.
