shop service/repair manual on disk
Cooper0809
Fergus, Ontario
got a manual on a disk today from the dealer, but it doesnt work. normally a window would pop up when you insert the disk, but theres nothing. dealer knows about it, said to bring it back. just wondering if anyone has experienced this or has any ideas on what could be wrong.
If your running window you should just have to insert the disk. Then go to "my computer" or just "computer" in the windows menu. Then it will show your hardrive which is C drive and any removeable drives. I/E your disc. Then just double click. It should load right up. Let us know if it works
if your on windows click on the windows icon bottom left. click on computer, then your disk drive. there you should see the disk. open that. there may be a few folders in there and you will have to go through them but you should find either a setup, install, or start up tab
ya its not working, its definitly the disk. im not seeing anything. gotta go back saturday and get gloves, oil, beleclava, and some other stuff, so i'll get him to burn another copy. thanks anyways guys!
yes, there is a drain bolt inside the tunnel. drain from there. If it were mine I would pull the cover after draining a inspect everything and clean any sludge in there. but I guess you could conceivably drain it and just refill it.
my home computer with vista didnt open a picture disc for me,i put it in my laptop with 7 and transfered it with a thumb drive,i would at least try it on another computer
went back to the dealer today, disk worked fine for them. still not on my computer, so i took it over to my buddies place today and got him to put it on a usb stick. so hopefully now i wont have to ask too many questions. we also got out on his little 340 enticer in his backyard today just playing around on the grass.
