srx rear heat exhanger
yamadogg
maine
have heard that when u put triple pipes on a 700 sxr u can put a srx rear heat exchanger on to help with the cooling but the nipples on the rear heat exchanger are bigger what to do now? :o| :o| any help would be great thanks ron
You need to go to a hardware store and buy two hose adapters[one for each side] that step the size up from your current rear exchanger hose size to the SRX inlet size. You will also need a length of heater hose that matches the large end of the adapter and joins it to the new SRX exchanger...a couple hose clamps /side will be needed as well.
if you just use the stock srx/viper hoses for the rear, you can use an automotive style clamp to shrink it down or you can cut a piece of the smaller hose to act as a bushing inside the larger hose. If you have only the small hoses, you need the larger ones. I have some if you don't, pm me if you need them.
also, check your sleds heat exchangers from one side to the other under your feet. I have seen lots of sleds with one full, and one half width style on the same sled, lots of extra cooling in that upgrade as well
