60 degree twist ?
Vtnaples
Vermont
Hi, how do I add the numbers to get this ? Is there a formula ? 2000 sx700r. Man, I hate being dumn to this stuff. Thanks for the help !
Im no cluch expert but it's just a matter of adding the bottom number + the helix number and X10. Example on my viper 70deg twist is stock. So 1 on clutch sheeve + 6 on helix is 7. Mult x10 wala! 70deg twist. This how it was explained to me. So 3 on clutch and 3 on helix should give ya 60deg twist. HEre is a great link i just remembered. http://www.totallyamaha.com/snowmobiles/aaTECH/drivespecs/secondarysprings.htm
Thanks guys, I havent taken it apart yet, but Im assuming you just pick the proper numbers and twist until arrows match up
Do the newer secondaries have six ribs on the back of the inner sheave like the older ones? That's how I set the twist on mine (granted I already knew which hole locations I needed). Each rib is 60 degrees apart so I went off of those.
