Fuel/oil mixture
Premix the gas to 50:1
50:1 ---> will give you 2,0 % 2-stroke oil mix.
This is quite enough for that engine.
:2strokes:
50:1 in a 95 enticer II LT as well, although I suspect it is a bit on the rich side. Everyone I know is running 50:1 in their bravos.
To jump on the 50:1 ratio band wagon and agree if anything its alittle more oil than you need. Does any one else remember back in the 80's when some stations had a 50:1 pump?
