Old Dad
I own a 1998 SRX. When dims are on everything works. When brights engaged, lose all lights. Any ideas? Thanks.
A couple of bucks
Possibly a faulty relay.
short. most likely under the seat or on the steering hoop.
SXr or SRX, just for clarity? bit of difference between the two.
Harness under the motor could be rubbed thru...
MrSled said:Harness under the motor could be rubbed thru...
ya, what he said..........
you can usually verify this by switching the headlights from low to high with sled running and the tach will jump around also.
use wire harness rub thru for the search, its all over this site, it was a common problem. not too bad to fix just kinda dirty.
