I've searched as much as I can, and have seen a couple pictures with people that have them on the ski shocks.
What I need is to replace my totally sagged crappy kyb ski shocks (03 Mtn Viper), I know that you can buy the drop bracket for the bulkhead from like a SRX/SX to get rid of the clevis style shock. But what length is needed for the fox floats in order to gain the way increadible front end lift that the sled needs desperately. If anyone can help out with the center to center on this that would be awsome
snoprokidf6
With a 16 in float i had to modify my brackets. I can post a picture tomorrow. Without modifying the bracket i'd say a 15 or 14 inch float would work
that'd be awsome, from what I had found that the stock KYB's are approx 15 3/8?
livewire_101proof
Pretty sure phazer ones would be close, and the eye is narrower so it fits ur mounts also.
snoprokidf6
here is that bracket. fairly easy modification, welding it can be a bitch as the bracket from yamaha is cast but it should stay attached haha
The bushings are from a stock yamaha RTX model, just shaved down so everything fits
