Viper Mtn parts going in the garbage soon
MtnMax600
Sacramento
I parted out a 2003 viper mtn a while back and still have a lot of stuff left. I am moving so, sad to say, its going in the garbage unless someone wants some (or better yet ALL) of it. Make an offer to make it worth my while, no reasonable offer refused.
Pics of most stuff here
Stock pipe and can-low miles
SLP can, a bit rough
exhaust deflector
Jackshaft
Steering post
Carbs
trailing arm mounts
fuel pump
oil pump
motor mounts
Stock Reeds
front heat exchanger
coolant bottle
coolant hoses
thermostat
headlight pod
rad rod-belly pan bracket
spindles and arms
brake caliper and rotor and e brake
brake controls
choke cable
clutch puller
under hood steering assy.
rail extensions 141 to 151
water pump cover
air box
oil bottle
recoil w/good rope
stator and flywheel
powervalves and servo
front bumper
coil pack
wiring harness
CDI and sensors
Ignition and key
crank with bad mag(or is it pto...) rod bearing
maybe a couple
Stock reeds, and reed cages? how much? also waht is the brand on the rail extensions and how much? Thanks.
P.S. after you give me these prices you should post in the 7 day classifieds. ;)!
