WIRING DIAGRAM? 99 phazer
chilli
North Bay, ONTARIO, CANADA
I dont like how the hot grips and thumb warmer are only controlled by the key in position II.
I have new grips, and want to tap into the wiring to bypass the key, and use the standard toggle switch with LO-OFF-HI
Also need to tap into wiring for electric shield install.
any help would be appreciated
Don't mean to insult you but it seems you are not aware that there is a rotary dial on the dash to set the temperature.
not on this model there isn't... no reostat or toggle whatsoever
none the less, already tied int the new grips with switch, and tied in for heated shield
