1980 SRX 440 secondary spring
srx70024
Westfield, MA
Could anyone suggest a good replacement for the stock secondary spring for my 1980 SRX 440. I am using a stock primary with stock weights and spring. I'm not racing this sled at all, just want a stock setup.
Thank you!!
stock yellow spring from what model sled? the secondary springs for the srx 440 are no longer available, so I'm trying to find what other model sleds I can use for a spring in the 440.
ok, but it looks like those models use the same part # that I have been trying to find... 90508-45286-00.
My exciter77 340 has a blue spring. I was able to get a yellow one out of a 79 440.
are you looking for new or good used ...........i have both
11-27-2012 12:23 PM
i could be wrong but i though only 76 340 used blue spring .....regard less the yellow is a bettter choice
Yamaha Nutz - If you have a new yellow one that would be great. If not, a good yellow will do. I will send you a PM with my contact info, if you could do the same, we can setup payment stuff. Thanks!!
Tony- These yellow springs are no where to be found, you guys must have bought them all up... LOL!!!
