what would you do????
yami1
western ny
Need some opinions out there. Put a vector skid in me sx last year. Really raised the *** end as you can imagine. So Want to level out the front. Did the viper shocks on front but that didnt raise as much as i thought it would. SOOO these are my options as I see it. Put stock hanger :letitsnow :letitsnow mounts back on and put eyelet mounts on top of shock and mount it that way instead of the present fork style that is on viper shock. Or find me some longer shocks with the eyelets style on each end. Or was wondering if any of you know if by putting different spring in front would raise it up. SEE SNOPROKID6 put rev springs on his viper and was wondering if others have tried. Sent snopro a pm but havnt got a response. Any other opinions????
You could find trailing arms for the sxr and other "wider stance" sleds and that should help with gaining some ground clearance. The SX's sat pretty low and only had about 6" of travel up front and the SxR's have more travel.. Do your home work shouldn't be to tough.
Bought some springs out of a rev today. Their like 12 3/4 in. long. Compared to the viper spring which is 9 3/4 in. This should pick up my front end a bit. Will post some pics when i get them in
