GS 340 crank seals
got-wood
In my skin
I have two of these engines that are both in need of crank seals. Is this exercise going to require splitting the case? Any suggestions on the best place to buy the seals and set of rings? Thanks.
yes it does if you cheat and do not take the whole motor apart and just pop the bottom half should only take about 30 min to complete ...........done it many times
