For all the questions about the pivot adapters
SXRider7Hundo
Northern IL
I finally got a few shots of the handlebar setup on my blue viper. It's a powermadd pivot adapter with a 6 inch riser and RSI 10 degree pullback bars.
And yes those are stock cables and brake line. I did extend the wiring however.
Just because I wanted to whore off my NOS deep keel blue skis and painted screens... :)
What did you do to lengthen your wires? I originally wanted to but wasnt happy with what i was comming up with. Love the bars! I went with the same set up just with apex bars which set me a bit higher then the flat bars so i had to put mtn cables on.
A lot of soldering Chris, and tons of patience. Lol. I just took my time and cut equal lengths and soldered an shrink tubed. I made sure to only lengthen the ends on the bar sides. Should I ever decide to go back to stock I can plug right back in to the main harness with a good used set of bars that have all the stock hardware and harnesses on them. No Mickey Mouse stuff that way.
