YAMAHIZAL700
Well when I replaced the headgasket I noticed I cut corners a bit when I rebuilt my motor years back. I reused a head that has a few dings around the edge. Not where the plug comes through but the outter area. I talkin like 2-3 small marks from probably a ring. I've run the sled for years without issue but could I see a performance increase if I replace with a diff One? Do these need to be perfect? Just looking for input. Thanks.
-jason
-jason
Devilin AblueDress!
Sounds like it would be fine, Or maybe its not
heads are relatively cheap though if your on the fence. We could chime in with better advice if we had a picture to see what you see.
heads are relatively cheap though if your on the fence. We could chime in with better advice if we had a picture to see what you see.I think I understand where you are talking about the chips being. Had a jetski that lost a cylinder and had a bunch of nicks in the head. We just carefully ground down the high parts by the nicks and put it back on. Ran amazing all last summer. You should be fine.
YAMAHIZAL700
That's what I'm thinkin just not sure if id add power having it be right.
99srxracer
I'm in laconia nh I've got srx heads in good shape let you have em for cheapYAMAHIZAL700 said:Well when I replaced the headgasket I noticed I cut corners a bit when I rebuilt my motor years back. I reused a head that has a few dings around the edge. Not where the plug comes through but the outter area. I talkin like 2-3 small marks from probably a ring. I've run the sled for years without issue but could I see a performance increase if I replace with a diff One? Do these need to be perfect? Just looking for input. Thanks.
-jason
YAMAHIZAL700
How much for one?99srxracer said:I'm in laconia nh I've got srx heads in good shape let you have em for cheap
99srxracer
60 bucks you can have all 3 of themYAMAHIZAL700 said:How much for one?
YAMAHIZAL700
ok sounds good to me. U want a check or PayPal?99srxracer said:60 bucks you can have all 3 of them
-jason
