what is the difference from a viper to srx ...i see that the parts number is not the same ?? anyone got a idea about it
3g racing
Just had a srx and a viper w arm repaired they seem to measure the same but the srx has some extra supports on top of w
3g racing said:Just had a srx and a viper w arm repaired they seem to measure the same but the srx has some extra supports on top of w
thnx very appreciated
probably the same as the SXR ones.The difference I can see is where the 2 support brackets that are welded on the inside bars where the limiter strap eye bolt goes thru.They are in different position by around 3/4" approx.So means longer or shorter straps.depends which w-arm you use.
