88 Excter secondary setting??
..SNAKEBIT..
NE IOWA
88 Exciter secondary setting??
trying to help a guy out but can't remember how the A B C and 1 2 3 4 settings worked and what twist they each had?
they would run at A2 or C2. Also, depends on what spring you are using the 87 came with the pink at C2 and the 88's came with the white at A2
so if I wanted to tighten it up what setting do I use???????????
is there a chart that shows the twist???
you need to find an old book and look it up, I could find it if you need to. C2 is 40 and A2 is 50 the white spring is stronger than the pink
