averagesleder
Sled '03 sxviper
I'm going to be replacing the left side panel on my viper. I've been looking at the parts diagrams and can't figure out which rivets I need to order. The rivets are metal and grey in color. There is about 20 or so rivets that hold the panel on.
http://partsfinder.onlinemicrofiche.../Yamaha_OEM/YamahaSnow.asp?Type=13&A=294&B=16
Number 36 is what I'm replacing
What rivets do I need?
super1c
Super Moderator
Ding a member here sells them for a grat price, or OFT racing also sells them and is a site sponsor. You want the large head 5/8 ones http://oftracing.com/OnlineStore/index.php?main_page=index&cPath=37
averagesleder
The size of the heads helps me out a bunch,thanks. However shipping from Alaska to Canada will most likely be fairly high.
musselman
I'm not 100% sure but I thought those rivets were aluminum. I just drilled out a bunch and they sure cut pretty easy unlike the rivets in the tunnel.
Check out sled toyz which is located in ontario, that's where I get most of my rivets.
Here are the aluminum 5/8" head:http://sledtoyz.com/component/virtu...ypage=flypage.tpl&product_id=77&category_id=6
Here are the steel ones if you want them: http://sledtoyz.com/component/virtuemart/?page=shop.browse&category_id=5
