Is there any difference in the years 98/99 and 2000+? I was thinking of buying 8CM-47421-50-00 but it lists it for 2000-02, would it work? Says its only ~$10 from a couple of sites on the internet, seems to good to be true.
apex/viper rider
i purchase for my 2000 sxr my 2003 viper n my 2003 rx1 with an m10 i use all the same hyfax the legnth is the difference thats what works for me where did u find them for 10 bucks
A couple of bucks
Those are more than likely generic and not beveled at the front.
Any slide listed for a pro action skid will fit,anything from 97 - 05 used the same rail profile if I'm not mistaken the length will be the only difference.Sliders will usually come sized for 136 or longer slide rails you just have to cut them to length.
bADa$$ SRX
anybody got any good tips to getting slides off? i always had a heck of a time haha
I use a bigger flat blade screw driver and a hammer. Carefully drive the screw driver into the side of the slide just enough that it has something to grip and tap it out.
A little wd40 helps too.
A couple of bucks
Once it's through the track window, I've used vice-grips and a hammer to 'persuade' them out.
staggs65
a little never-seize or grease on the rails will help for next time.
My issue getting them off was the track window was way too small and had a heck of a time getting them thru the window. Was a real nightmare.
apex/viper rider
the window will flex just spray wd40 its tuff but will pull thruSRX_700 said:My issue getting them off was the track window was way too small and had a heck of a time getting them thru the window. Was a real nightmare.
A slide-hammer (no pun intended) with a screw-in attachment works very well for removing slides, especially if you want to replace them with the track still installed. I've been using this method for years now.
-Mark
-Mark
A couple of bucks said:Those are more than likely generic and not beveled at the front.
Really? The part no I listed was specific to a machine and was a yamaha OEM number. I was just surprised that it was ~$10. I don't want to post a link here because most forums don't like links posted to commercial sites, but if you do a google search on the part number it'll show you the sites that carry it and its price (and they have the machines it goes to cross listed).
fourbarrel said:Any slide listed for a pro action skid will fit,anything from 97 - 05 used the same rail profile if I'm not mistaken the length will be the only difference.Sliders will usually come sized for 136 or longer slide rails you just have to cut them to length.
awesome, thx!
I can get them from a shop about 4 miles from my house for $13 a piece.
I used 8cms on my SXR once. They will fit and they are beveled. Theyre OEM-all the Yammie slides I've used are ready to roll when you get them.
Installed the hyfax's yesterday and they went right in. Perfect length and everything. They slid right on, whereas the aftermarket ones that were on there I had to beat pretty hard to get off. $10/piece well spent.
Putting the skid back in was easy once I did a search that said to put the back end way way up to get the front part of the skid in. I struggled for 2 hours to put it in with it up about 3-4' (all the travel I had), then I rigged up another way that got it well above 45 degrees and had no problem after that.
Glad I got in there, one of my track clips was torn apart and chewed up the hyfax. Crazy as I only have about 100 miles on the last set. Must be all the gravel roads VAST makes us go on.
