NY AttakGT
Anybody know what sled these front Heat Exchanger protectors fit or have a Yamaha part#? I bought them a few years back and they have been sitting in a parts box in my garage.
The ones I took out of my '01 SRX a few years back were slightly different as the ones pictured below. SRX ones had rivet brackets at the top and were riveted to the tunnel and these only have 1" round shafts at the top and rivet at bottm. Any idea?
Any trailing arm sled these will work on
they fit all pro actions. They are made to install in a sled without removing track. You drill a hole up in the tunnel with a long drill, then slide the top into it and rivet the bottom. They are a great Idea and work well, other than, over time, the end can chafe through. When installing, there needs to be lots of silicone around the hole and pin, as well as some along the side that touches the heat exchanger to keep vibration down. 20 bucks is the norm for a set used.
gil7247
They look just like the ones I bought from HPE. If you want to sell them shoot me a pm I've got a 98 that I should put some on. Thanks Gil
NY AttakGT
gil7247 said:They look just like the ones I bought from HPE. If you want to sell them shoot me a pm I've got a 98 that I should put some on. Thanks Gil
We got a winner!! I must have bought them from HPE when I bought my offset rear axel and aluminum spoked idler wheels. Thanks for the input everybody. $30 shipped in US if you wanted em. Never used or installed. Have some rivets I'll throw in too.
snowxmech1
- Feb 1, 2004
does anyone know if the stock front tunnel protectors on a 02 srx, will work with a 1in track?
yep mine does..
