Power valve pull through??
Agpetro
Petoskey, Michigan
Started going through my viper tonight getting it ready of the season. Started off by cleaning the power valves. Pulled one of them out and it seems like its barely on there compared to the other two. Is it about to pull through??
pull the valve out and you can remove it from the cable. Clean it up and then take a small light and look thru the end of the valve, youll see a small hole worn in the top end of the valve, if so.... its ready to pull thru and you need to get it repaired or replaced.
Easy enough to find out, just pull the valve off the cable. I just take some channel locks wraped in a wrag and unwind the servo valve then gently pull on the valve and it will expose the end of the valve from the housing for inspection or replacement. Could be starting to mushroom? For sure check it.
It will be a piece of cake for ya. Just gently rotate that servo clockwise unwinding cables (best if all three out) and then slowly pull the valves from the housing. Let us know what ya find?
Cooper0809 said:
Just replying so I can find it easier when it comes time to adjust....
Just go under user cp. Find list subscriptions and then create a new folder callled tech section or whatever. Then you can save all the good threads under your new folder and you will always have them at your fingertips. This is what ive always done. Also when finding a new post you want just go unter thread tools and save it that way without having to post. Hope this helps ya, just easier to find that important info you want to keep handy. Its also in the tech section.
awesome! i appreciate the help.
thanks, jeff
