waterline mobile marine
I doing my top end on my 1998 SRX 700 and im at a stopping point cause the new piston kit for the one CYL. that im replacing has a thicker piston pin then the other two stock pins. So while im waiting to see what everyone thinks about using this pin or not im finding out if i should use Yamalube 4 on the metal base gasket.
So should i put a thin layer of Yamalube 4 on the gasket or should i use something else?
Any help on these two problems im at would help alot, I do outboards and they are a little diff then them, so im asking before i find out the hard way and costly way!
THANKS
THANKS
