jthemmer
The black caps that face up on the carbs when installed on the viper. One of my caps has a nipple that a vacuum line feeds into from my holtzman dial a jet. The nipple broke off the cap. Any ideas where to get a replacement cap for this that comes with the nipple? Or is this a modified thing?
Do you have any pictures?
richierich
I might have some brand new nipples.Your talking about the aluminum fitting in cap correct ? Let me know and i'll go look.Rich
usually you epoxy the nipple in the cap as I remember when I installed dial a jet years back...if I remember correctly.Post us a pic.
thefindian
I have one but I need to find a cap without a hole because im taking the dial jet off this sled i could sell the whole dial jet thing if you want?
richierich
jthemmer
Okay yes that is the picture of what it was. However, I did not break the nipple, it actually just separated from the cap. So all I have to do is epoxy it back in? And it shouldn't leak air?
Also, everybody thanks for the help on this in advance. This is my first sled and I was cleaning carbs and putting everything back together when that nipple fell out.
richierich
Ahh ok you can just epoxy it then.Long as you have enough epoxy you wont have any leaks..Just make sure to clean surface good so the epoxy adheres to it.
jthemmer
sounds great thank you!
