mountain max reverse kit
waynemags
alberta canada
anyone done the reverse kit on a mountain max 600. its a 2001. oem yamaha kit. wondering whats all involved. im pretty good mechanically so no worried about that. just looking for some words of wisdom if anyone has done it.
Never have done it on a mtn max. Have done it to an 05 Vector Mtn. though. Basically you will drain the chaincase oil. Remove chaincase cover. Remove the bottom gear. Then put it back together with the parts from the kit. Add oil. Adjust shift linkages.
Other than that, I can't offer you any tips or tricks to it. Just take your time. Lay everything out and keep it seperate.
reverse
Pretty simple, just have a breakdown of the gearbox to insure you put it together correctly. I use the parts breakdown on line.
reverse
If you run into any problems give Chris (Super1c) a shout he's done a couple of them and his Vipers as well as adding electic starts. He's a great guy and will help you out.
He helped me a ton on little stuff here and there. Gil
