srx 600
kruserw
minnesota
Can a yamaha srx 700 trailing arm fit a yamaha srx 600 1998. And if so is that any year will fit it.
So long as you dont mind the stickers being slightly different! If you look at the radious rod bracket theres a letter stamped V I belive with the arms your talking about. I have a 98 srx 600 that has arms off from a 97 sx700 (red) If the letter matches then it will interchange. Bluemonster1 just had a thread about going SxR to SRX. Even that will work, slight differance in angle of spindle tube due to 8 versus 12 1/2 suspension travel of two different models.
