Waterfoul
This happened tonight.... after I got it back in the truck thank goodness... was pulling on the handlebar to move the front over a little and it came right off.... the end is broken too... As most of you know, I'm new to the snowmobile club (after many years of absence) and would like some advice on how to fix this.
Thanks,
Mike
Thanks,
Mike
best bet is just replace with a new one. if the end is broke the heaters will start to short out.
You will need a new grip. There is a plastic spacer inside the grip where it broke.
Waterfoul
Dealer the place to get one??
Yep Dealer is the best spot. OEM grips are the way to go.
Waterfoul
$25 at the dealer. Heading that way after lunch. Close at 6 so I'll have to rush!!
