03 viper hand warmers wont work
YZViper366
Lifetime VIP Member
Bismarck, ND
Just like it says in the title my grip warmers wont work how do i pinpoint the problen? Are ther fuses to check?
first thing to check is the continuity on the grips themselves.
find the bullet connectors under the bar pad for each grip, seperate them, and test each grip independantly. if one grip is bad, neither will work.
from there, there can be several other contributing factors but its quickest and easiest to rule out the obvious.
My handwarmers would not work on my 2001 MM700. Checked connections and continuity on grips. Perfect. Turns out, the handwarmers go through the CDI. WTF. Changed out CDI for new. Handwarmers back. I hope this is not your problem. Expensive repair.
X2 ;)!
It is starting to look like it is. I checked all the continuity points and all good and i tested the wires going to the cdi and the test light would not light. So im assuming that means cdi is the problem. Correct?
I wouldnt rule that your problem just yet. The variable resistors(adjustment knobs on your dash) would be the next thing I would check. Mine went bad last year and had to replace them. Problem solved. However, when the resistors go bad you should get a trouble code flashing on your dash. Even if your not getting a code I would still check them before deciding to tear into the CDI. That's expensive just for grip heaters IMO.
How do.i check them? Same way i checked for conuity on my grips? Because id did that and they tested out
Use an ohm meter on the leads of the resistors. As you turn the knob it should change resistance.
Test lights are nice when when looking for power but multi meters are better when diagnosing electrical problems.
Mine went bad last year too but i had a short cause it was draining my battery, i went to the junkyard and got a set of used ones to put on.
