PPS. inc
How many clips on a stock 121 viper? Missing a few and the rest are worn.. Same amount on a 99 srx? None missing, just worn down to rubber in a few places
SWEDE
Should be 96 clips if clipped every window.....
PPS. inc
Just removed all clips. They were toast. Came off with almost no force. Got a part number for these clips? This is exactly why this site is great. I will post some pictures of the sleds when there is white stuff on the ground. Thanks guys!!!
From the fiche for 99 SRX:
2 PLATE, REINFORCEME - 8EA-47113-00-00
3 METAL, SLIDE - 8EA-47115-00-00
I remember when we used to replace clips on the tracks. Once all the clips are replaced and installed, you basically are very close to the price of a new track. Again, if the clips are worn that far, the track is probably worn out too. Good luck Al
Are the clips you find aftermarket any cheaper?
PPS. inc
Got the tool. 96 clips will cost about $100.00. Pry 2 or 3 hrs to clip out. The track has 3000 miles. It's perfect when inspected. Are the guided clips necessary? Local powersports said they didn't have a part number and said their book did not call for guides. I don't know I thought they were absolutely necessary
