42 Degree Helix on a Viper?
DetroitViper
Macomb, MI/Phoenix, AZ
I bought a used heel X roller secondary, which has a 42 degree helix. I'm about to install the heel clicker clutch weight, I called the guy from Super Tourquer and he told me to put 1.2 grams in the shoulder, center empty and 6.3 in the tip. Does this sound correct, and what can I expect from this setup? I beileve that is is a top speed set up on the Viper, but I'm not sure. Any ideas would help thanks!!!!!! Also what spring in the primary red or gray?
