Has anyone ever put rear springs from a 91 venture 480 on a phazer II? looking for a stiffer set, does the st have heavier springs than a standard phazer II ???
low slung
If you want really stiff springs(2up riding)get a set of springs from a 1992-2001 ET410II.
XLV springs will be much stiffer. I run mine on the softest setting with a nitro shock and its still stiff. I weigh 192 lbs.
