Tach Stepper Motor?
thegrizzly1
Previous sleds:
Chisholm Mn.
When I first started the viper last night, I idled it way down to get the power valve servo motor opened up so I could set the power valves. I noticed once I got below ~700RPM the tach would occasionally cycle just like it does on startup. Is this normal? I’m thinking is because I had the idle set so low, but want to make sure. Didn’t seem to be a problem with the idle over 1000RPM.
