Hi !
Does someone here at TY know what the maximum track lug height is
on Exciter-II with stock 9-Teeth drivers ( 1991 - 1993 ) up in front at the drivers ?
32mm if you lower the midle axle 25-30mm
The middle axle is not a problem since I not using a Yammi skid.josen said:32 mm if you lower the midle axle 25-30mm
©RxSX
Lasse said:up in front at the drivers ?
I don't think that is where you will run into problems first.
