SRX7
That means your center shock is a little stiff ?
If it is its to bad, cause I can take the bumps alot harder.
Bigmax
From my experience I get that when I don't have the track sitting flat on the ground and tipped up in the back.
B2SO
- Aug 18, 2003
it means you have to much ski pressure , either let out the limiter strap or but more preload on the center shock ..
Or it means you are like us, and you have 2 inches of ice under the snow. Maxdlx
Yup
2 OR 3 inches of ice.
SRX7
Its funny you say that we do have lots of ice and maybe its only that.LOLmaxdlx said:Or it means you are like us, and you have 2 inches of ice under the snow. Maxdlx
WicksViper
- Jan 9, 2005
I've got the same thing on my viper thought it was too much carbide gonna try the shock in the back first thanks!
yamyrider
Hey SRX7 if Ottawa in anything like here in Sudbury right now it is alot of ice.
lol.
lol.
Waterfoul
Just add more studs!!!!!
blue who
i found that means the centre shock has gone soft or the shaft that holds it is broken and will cause rail damage if not fixed.good luck
SRX7
Yamyrider: Hell we have ice ontop of ice and we have freezing rain on its way for wed and thurs.Rrrrr
Bluewho: nothing broken,I think its just icy trails or the center shock is a little to stiff and I have to soften it by a couple of mm and test.
blue who
thats cool your post brought back memeries of wifes sled last ride of 04 it was swaying all over the place and took out one rail and one track after the rail snapped from the shock bracket being snapped.was hoping to get the day out of it but////that was all she wrote
B2SO
- Aug 18, 2003
SRX7 said:Yamyrider: Hell we have ice ontop of ice and we have freezing rain on its way for wed and thurs.Rrrrr
If you put less preload on the center shock it will get worse that gives you ski pressure , make sure you tighten the nut down ...
